API, Check or uncheck % of Model(actual)
Does anyone know how to actually check (or uncheck) the View Option\Deformed style '% of Model (Actual)'?
I know how to change the absolute and relative scale values, but in the API I just can't find the property to check or uncheck this checkbox.
Maarten Elings | Engineer
Re: API, Check or uncheck % of Model(actual)
That checkbox is connected to the .draw Property of the View Object, this code gets the Active View, loads it, checks to see if the option is checked, and processes accordingly.
Mark.
The HTML Clipboard
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim viewID As Long
    Dim feView As femap.View
    Set feView = App.feView
    App.feAppGetActiveView( viewID )
    If feView.Get( viewID ) = FE_OK Then
        If feView.Draw( FVI_DEFORMED_STYLE ) Then
            feView.Draw(FVI_DEFORMED_STYLE) = False
        Else
            feView.Draw(FVI_DEFORMED_STYLE ) = True
        End If
        feView.Put( viewID )
        App.feViewRegenerate( viewID )
    End If
End Sub
Thanks for the quick reply!
no wonder i overlooked it.
