Can't Delete Points
Hello, I have some points in my model that I can't seem to delete.  They are on one of my surfaces but are not removable.  When I draw erase my surface they are on the points are still visible but when I delete the surface they disappear.  The points are not forcing a mesh through them but they are definitely associated with the surface.  Any suggestions?
3 REPLIES 3
Re: Can't Delete Points
You can use the  Meshing Toolbox's Feature Removal tool to delete points on a surfaces.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
I have tried that. It won't delete by using any method I have tried.
It could be that the points are mesh points.  Try the Mesh Points on Surface command to remove points.
Also, try the Geometry, Solid, Cleanup command using the Advanced Cleanup command.
I'll assume your model is proprietary, so if you can, please send me a snapshot of the surface in question to chip.fricke@siemens.com.  Also. what version of Femap are you using?
Best Regards,
Chip Fricke
