Error tracking nodal displacement in model before/after analysis
I am able to create a list of nodes prior to running my analysis for a wing bending due to a thermal load. However, after my analysis is complete, I cannot use "List--> Output--> Results to data table" as the option is greyed out.
This is strange considering I can click on both the deformed and animated views of my model and see the displacement occuring, as well as look at the actual displacement in inches via the contour graph; but I want to be able to track all of the nodal displacements.
Any suggestions? Can attach file later on if necessary.
Thanks!
Re: Error tracking nodal displacement in model before/after analysis
Did you have the Data Table pane visible in FEMAP when you tried to list to it from the menu?
OmarM
What do you mean by the Data Table pane?
The data table pane is the dockable pane that data gets listed to in table format. You can learn more about it in Section 7.2.11 in your "Commands" pdf. To make the pane visible in FEMAP, go to Tools->Data Table from the main menu. After doing that, try listing output to it again.
