Re: FEMAP Fatal error when running example
Thank you for attaching your model.
I have used modal analysis before to test models considering rigid body motion, and this is not the case (I am aware now my last post was wrong regarding the fixed support on curve, this was not the case on other models however)
run the model you attached and got the same error.
This is strange. I download my model, import it to Femap 11.4.2, run it and get no errors.
