FEMAPcsv result import - corner data
I'm having trouble creating CSV output with corner data.
cf test files attached, when I import model+results the results dont contain the last corner.
In the help it clearly says we should skip corner #4 for tetras.
Thanks for the help,
AP
1 REPLY 1
Re: FEMAPcsv result import - corner data
It appears there is a problem reading comma-separated files. Try attaching rather than reading the file. It worked for me. We will investigate further and get this fixed.
