Femap v11.4 Neutral File Reference Document
Please note that the Femap Neutral File reference pdf file included when installing Femap v11.4 is incorrect.  If needed, you can download the attached pdf file and replace the existing pdf\neutral.pdf file under your main Femap installation folder.
The document located by the Help > More Topics > More Resources command is the same document as the attached and does not need updating.
The correct document will be included in the next release of Femap.
Best Regards,
Chip Fricke
