Find the vol and cg of a solid part using API
i am kind anew to the API world, any help would be highly appreciated.
so far i have managed to make a solid body in which the code asks the user to input the length, bredth and height to make a cuboid.
now i want to slice the solid using a user defined plane and find the volume of the remaining solid.
once this is completed i want to slice the remaing solid using (say 10;number of planes inputed by the user) equidistant planes and find the volume and cg of each of these slices.
Version:1.0 StartHTML:091 EndHTML:000003499 StartFragment:246 EndFragment:000003460The HTML Clipboard
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim feCSys As femap.CSys
    Set feCSys = App.feCSys
    Dim l As Long
    Dim b As Long
    Dim h As Long
    rc = App.feGetInt("Length", 0,1000 , l)
    rc = App.feGetInt("Breadth", 0,1000 , b)
    rc = App.feGetInt("Height", 0,1000 , h)
    Dim size As Variant
    size = Array(l,b,h)
    Dim cs As Variant
    cs = Array(0,0,0)
    Dim Area As Long
    Dim vol1 As Long
    Dim CG As varient
    Dim Inertia As Variant
    Dim s As femap.Set
    Set s= App.feSet
    s.AddAll(FT_SOLID)
    Dim g As Group
    Set g = App.feGroup
    App.feSolidPrimitive(0, 1, True,cs,size, "tank 3d model")
    rc= feMeasureSolidmassProp(s.ID, Area, vol1, CG, Inertia)
    App.feAppMessage( FCM_NORMAL,Str$(vol1) )
End Sub
i cannot make the femeasuresolidmassprop to work. please provide some help
Kind regards
John
3 REPLIES 3
Re: Find the vol and cg of a solid part using API
The HTML Clipboard
Sub Main
    Set App = feFemap()
    Dim l As Long
    Dim b As Long
    Dim h As Long
    Dim size As Variant
    size = Array(l,b,h)
    Dim cs As Variant
    cs = Array(0,0,0)
    Dim Area As Double
    Dim vol1 As Double
    Dim CG As Variant
    Dim s As femap.Set
    Set s= App.feSet
    s.AddAll(FT_SOLID)
    Dim g As Group
    Set g = App.feGroup
    rc= App.feMeasureSolidMassProp(s.ID, Area, vol1, CG, Inertia)
End Sub
Here are some changes to your script. You needed Area and vol1 as Double because they are REAL8. Also you needed App. in front of feMeasureSolidMassProperties
Thanks for the reply.
got it to work, but the output shows zero insted of the correct vol. how can i correct that? and could you please help me to use the solid slice option uisng a user defined plane
kind regards
john
The HTML Clipboard
Sub Main
    Set App = feFemap()
    Dim pl As femap.Plane
    Set pl = App.fePlane
    Dim pBase As Variant
    Dim pNorm As Variant
    Dim pAx As Variant
    Dim s As femap.Set
    Set s= App.feSet
    Dim sTrack As femap.TrackData
    Set sTrack = App.feTrackData
    Dim sID As Long
    Dim l As Long
    Dim b As Long
    Dim h As Long
    Dim size As Variant
    size = Array(l,b,h)
    Dim cs As Variant
    cs = Array(0,0,0)
    Dim Area As Double
    Dim vol1 As Double
    Dim CG As Variant
    Dim g As Group
    Set g = App.feGroup
    sTrack.Start(FT_SOLID)
    sTrack.Created(FT_SOLID, s.ID, True)
    sID = s.First
    rc= App.feMeasureSolidMassProp(sID, Area, vol1, CG, Inertia)
    App.feViewRegenerate(0)
    App.fePlanePick("Select Plane for Slice", pBase, pNorm, pAx)
    App.feSolidSlice(s.ID, pBase, pNorm, True)
End Sub
Try using this
