Margin of Safety API with FEMAP
Hi guys!
I am new in API developmet. I am trying to create a API that give me the MS for plate elements.
My probles is that the API make the analysis with the allowable of the first material that it get.
Could anybody gime a hand?
The HTML Clipboard
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim OutVec As femap.Output
    Set OutVec = App.feOutput
    Dim OutVec1 As femap.Output
    Set OutVec1 = App.feOutput
    Dim OutVec2 As femap.Output
    Set OutVec2 = App.feOutput
    Dim OutSet As femap.OutputSet
    Set OutSet = App.feOutputSet
    Dim Oset As femap.Set
    Set Oset = App.feSet
    Dim e As femap.Elem
    Set e = App.feElem
    Dim p As femap.Prop
    Set p = App.feProp
    Dim eset As femap.Set
    Set eset = App.feSet
    Dim m As femap.Matl
    Set m = App.feMatl
    Dim  EOutputSetID As Long
    rc = Oset.SelectID (FT_OUT_CASE, "Select Output Set", EOutputSetID)
    If rc = 2 Then
        GoTo Bailout
    End If
    OutSetID = OutSet.NextEmptyID
    OutSet.title = "Factor of Safety - From Output Set "+Str$(EOutputSetID)+"."
    OutSet.Put (OutSetID)
    eset.AddRule ( 17, FGD_ELEM_BYTYPE )
    eset.AddRule ( 18, FGD_ELEM_BYTYPE )
    OutVec2.InitScalarAtElem (OutSetID, 9000001,"Factor of Safety - Tension", FOT_STRESS, False)
    App.Info_ActiveID (FT_OUT_DIR) = OutSetID
    OutSet.Get (EOutputSetID)
    OutVec.setID = EOutputSetID
    OutVec.Get (6039)
    eid = eset.First
    While eid > 0
        e.Get ( eid )
        outval = OutVec.Value (eid)
        PID = e.propID
        MatId = p.matlID
        m.Get (MatId)
        mtype = m.type
        Tension = m.mval (52)
        e.Put ( eid )
        OutVec1.Value (eid) = FoSC
        FoST = (Tension/outval)-1
        OutVec2.setID = OutSetID
        OutVec2.ID = 9000001
        OutVec2.Value (eid) = FoST
        SkipFOS:
        eid = eset.Next
    Wend
    OutSet.ID = OutSetID
    OutVec2.Put (9000001)
    Bailout:
    App.feViewRegenerate ( 0 )
End Sub
Re: Margin of Safety API with FEMAP
Try adding p.Get(PID) right under "PID = e.propID"
Thanks! now it is working!
