Normal Modes analysis with thermal loads
Hello All,
How can I make Normal Modes analysis with thermal load? I have surface to surface glue conditions in my model and SOL106 is not good choise. The main goal is to conside the thermal influence on E modulus and consequently on model stiffness.
Best regards,
Arcady
Re: Normal Modes analysis with thermal loads
Not sure what you want to do.If you want to introduce also the stresses / stiffness variation induced by the thermal loads you may consider to perform a previous static analysis (modal prestressed analysis).
Hope it helps
