Passing a Femap.Set to a function or another sub
  Is it possible to pass a femap.Set (App.feSet) to a funtion or a different sub?
Function/SUB Test(SurfaceSet as femap.Set)
Frédéric
Re: Passing a Femap.Set to a function or another sub
Yes:
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim set1 As femap.Set
    Set set1 = App.feSet
    set1.Add(66) : set1.Add(123)
    test(set1)
End Sub
Sub test(feset As femap.Set)
    feset.Debug
End Sub
Here's just another option that might work for you,
The HTML Clipboard
Dim eSet As femap.Set
Sub Main
    Set App = feFemap()
    Set eSet = App.feSet
    eSet.AddAll(FT_ELEM)
    Call list()
End Sub
Private Sub list()
    App.feAppMessage(FCM_ERROR, "There are" + Str$(eSet.Count) + " elements in the model")
End Sub
