Proper pyfemap commands and sequence to re-orient model and take a pic (repeat x-number of times)
I have a VB script that captures the active view of a model to include modifying the Contour, FVI_Criteria_Pass, FVI_Criteria_limits, CriteriaMax/Min, etc.  Once updated, I perform a feFilePictureSave2.  From there I perform the following series of steps three times:  rotate --> autoscale --> take a pic.  Four pics in total.
In my current python script, I'm able to successfully capture the first picture (i.e., contour updates), but not successful in capturing subsequent pics.
My question is what are the proper pyfemap commands and sequence to capture the next set of pics after a change in orientation.  The 1:1 mapping of VB commands to python does not work.
fview.Contour = 2 #turn on criteria
fview.SetLabel(constants.FVI_CRITERIA_PASS,0)
fview.CriteriaMax=1.1
fview.CriteriaMin=0.5
fview.SetLabel(constants.FVI_CRITERIA_LIMITS,3)
fview.Put(viewID)
app.feViewRegenerate(viewID) #'refresh the display
fview.OutputSet = outSetID #select to display data from output set 1
fview.ContourData = outVecID
fview.AutoscaleAll(True)
fview.SetDraw(constants.FVI_NODE,False)
fview.Put(viewID)# 'write the view object data to Femap
fview = app.feView
[rc, viewID] = app.feAppGetActiveView()
app.feFilePictureSave2(False,0,12,rpt_path+'\\Zpic_1_xy_'+strnum+'.png') #success
# Here's the transition from pic1 to pic 2. Commenting statements on/off to find right combo
#fview = app.feView
fview.Rotate(0,0,0,1,0,0,-90)
fview.Rotate(0,0,0,0,1,0,90)
fview.Put(viewID) #write the view object data to Femap
app.feViewRegenerate(viewID) #refresh the display
fview = app.feView
app.feFilePictureSave2(False,0,12,rpt_path+'\\Zpic_1_xy_'+strnum+'.png') # Pic 2 was not a success
Thank you
1 REPLY 1
Re: Proper pyfemap commands and sequence to re-orient model and take a pic (repeat x-number of times
Found the answer after stepping away from my desk.
#model orientation
app.feFilePictureSave2(False,0,12,rpt_path+'\\Zpic_2_xz_'+strnum+'.png') # pic 1
#start of pic 2
fview = app.feView
fview.Get(viewID)
#  Perform model orientation or what not
#repeat
