Starting FEMAP API Script without opening FEMAP
Hi all,
Is it possible to start Femap API script without acctually opening FEMAP? Like for example by command line or something?
I wanted to create larger script that would require that...
G
Re: Starting FEMAP API Script without opening FEMAP
I believe what you are looking for is the  > CreateObject < functionality.  You can then choose to make FEMAP visible or not.  In the screenshot below I am using Visual Studio 2017, but the code is nearly identical if you wanted to perform the task from Excel or another IDE.
Thanks!
I'll try it out!
