View labels toggle removed all numbers together
Innovator
Innovator
Hi all
I accidentally toggled the view numbers off in the contour view, but when I pressed it again, all the elements numbers apeared together with the axis labels that I wanted.
How can I toggle off element number view and toggle on the axis names labels and only some specific node numbers ?
I use FEMAP V 10.3
Re: View labels toggle removed all numbers together
Hello!,
You need to create groups with the entities where you want to postprocess results, and to control plotting entity label click F6 and select each entity, there you have options: 0..No labels, 1..ID, and so on.
Best regards,
Blas.
WEB: http://www.iberisa.com
Innovator
Innovator
Thank you very much
