Viewing problem
I'm new Femap user n needed help to remove the zip zag lines or elements in the undeformed view from the post processing results view.
Thanks in advance.
Re: Viewing problem
From the menu, please go to View - Select and tell me what you have picked under "Contour Style"....
Mark.
Re: Viewing problem
This is what I hv select.
TIA.
Re: Viewing problem
Kain,
I am not sure what the zig-zag lines are in the image you posted. Can you do /Help/About and capture an image of that dialog box and send that. Also, in /File/Preferences, in the graphics tab, capture an image of that dialog box and send that too.
