create Cut section in FEMAP V10.3
Builder
Builder
Hi All
I checked  this post , but when I use it the plane does not cut my contour result. how should I do that ? I do not know which vlaue on value and delta I should choose, it is not dynamic cause each time I should hit OK
Re: create Cut section in FEMAP V10.3
Builder
Builder
Anyone ?
Maybe problem in this: FEMAP V10.3.
This version is too old there are few users who can repeat your problem on v10.3. Also you don’t upload example file.
But I think it is possible to make section cut in V12 and export file to V10.3 via .neu format. But I need example file to see what setting you apply in your case.
Have you tried using the Clipping Plane?
