Re: error 9058
@MUJO
I believe the mesh is failing on the hollow part of the pedal spindle because of its shape. It's having trouble generating tets around the point in the region I circled below. This a section cut to show the inside of the geometry.
Re: error 9058
Thanks! I will try to remove this spot.
