pick by faces API
I want to use the "entity selction / pick / by faces ..." method in an api script.
Does anyone know how to access this method?
Re: pick by faces API
What type of entity are you selecting? If it's elements, try using the .feGetElementFaces(....) method.
Use the app.feGetElementFaces method.  Example code shown below
Sub Main
    Dim App As femap.model
    Set App = feFemap()
    Dim rc As femap.zReturnCode
    Dim elSet As femap.Set
    Set elSet = App.feSet
    Dim initCount As Long
    Dim origElIDs As Variant
    Dim origFaceIDs As Variant
    Dim elCount As Long
    Dim elIDs As Variant
    Dim faceIDs As Variant
    rc = App.feGetElementFaces ( "Select Element Faces", initCount, origElIDs, origFaceIDs, _
        elCount, elIDs, faceIDs )
    If rc = FE_CANCEL Then
        End
    End If
    'Test to Show What Element Face IDs Where Selected
    initCount = elCount
    origElIDs = elIDs
    origFaceIDs = faceIDs
    'Add the Array of Selected Elements into a Set
    rc = elSet.AddArray ( elCount, elIDs )
    If rc = FE_OK Then
        App.feAppMessage ( FCM_HIGHLIGHT, (Str$(elSet.Count) + " Elements where added to Set ID" + Str$(elSet.ID)) )
    Else
        App.feAppMessage (FCM_ERROR, "No Elements added to the Set" )
    End If
    App.feViewRegenerate ( 0 )
End Sub
Best Regards,
Chip Fricke
Dear Chip and Giampietro,
Many thanks for your hint!
since I work on a program without user interaction I'll try the feGetElementAdjacentFaces Method instead.
