Femap Version 12 Multi-step Nonlinear Demonstration
Community Manager
 Femap version 12 NX Nastran multi-step nonlinear demonstration video
New in Femap version 12 is support for new NX Nastran multi-step nonlinear solutions. The following video shows a demonstration of a heel-and-toe analysis using the NX Nastran SOL 401 multi-step nonlinear solution sequence. This end to end demonstration also shows the creation of simple geometry, hex meshing, application of washer and pad to aid meshing, use of a free body diagram, application of CBUSH elements with loading function, use of a API program, and analysis using SOL 401 multi-step nonlinear solution sequence.
(view in My Videos)
