Stress Linearization
I would like to ask you if is in Simcenter NX Nastran (11) any function/tool/solution for Stress Linearization of the results of the structural analysis (of a pressure vessel)? I only find "The FEMAP Stress Linearization Tool"  but that is (of course) the plugin for Femap only.
Thanks in advance for any answers!
Frank
Re: Stress Linearization
Here is the NX utility. There are 2 versions attached. StressLinearization.zip will run in NX 7.5 through NX 10. Stress_Linearization_NX11.7z is an update to fix api methods that were removed in NX 11.
Note that the Femap tool was based off of this tool.
NX 11 version
perfect, thank you very much!
F.
Is there a version of this tool for Simcenter 12, otherwise it is planned?
Marie
Yes, here it is.
Thank you Jim !
Marie
