Stress Linearization
I would like to ask you if is in Simcenter NX Nastran (11) any function/tool/solution for Stress Linearization of the results of the structural analysis (of a pressure vessel)? I only find "The FEMAP Stress Linearization Tool"  but that is (of course) the plugin for Femap only.
Thanks in advance for any answers!
Frank
Re: Stress Linearization
Here is the NX utility. There are 2 versions attached. StressLinearization.zip will run in NX 7.5 through NX 10. Stress_Linearization_NX11.7z is an update to fix api methods that were removed in NX 11.
Note that the Femap tool was based off of this tool.
NX 11 version
perfect, thank you very much!
F.
Is there a version of this tool for Simcenter 12, otherwise it is planned?
Marie
Yes, here it is.
Thank you Jim !
Marie
Hi Jim,
I get an error when trying to use the stress linearization tool for NX 12.
I pu the files here:
f:\NX\application
StressLinearization_nx12.dll
StressLinearization_nx12.pdb
StressLinearization_nx12_bs.dlx
and
f:\NX\udo
StressLinearization_nx12_UDO.dll
StressLinearization_nx12_UDO.pdb
and after seeing the error, I added
d:\NX_Open\StressLinearization\NX12.0
31/05/2018  12:08    <REP>          VB
31/05/2018  12:08    <REP>          VB_UDO
with the respective vb files in the directories.
What could be wrong about this?
best regards,
Cyril
Is f:\NX defined as UGII_USER_DIR, or as an entry in UGII_CUSTOM_DIRECTORY_FILE?
Can you post a copy of the NX syslog from the run?
Hi JimB,
thank you for your answer.
There is no UGII_USER_DIR defined, and custom_dir.dat is empty.
Thanks to your remark, I have set this variable and now it works perfectly.
I will send you the syslog privately.
Thank you very much,
best regards,
Cyril
