Assembely expression
Builder
Builder
I want to create an assembly part by adding components. For position the components, i create an expression, and then use it to specify the location in Add Component window. After that, i can see the expression in the part navigator. However, when i change its value, the part location is updated. So i am wondering if my way is correct. If it is not, what is the correct way?
Kang
