Bonded components in Nx
Builder
Builder
Hi
Do you have any case study, an example for modelling bonded components of different material in NX.
I have metal bonded to composite material-laminate by using epoxy. Assembly of three material.
different methods might be used to model the bonding; contact (define spring-stiffness), mating the components (tie), glueing (what about its accuracy)
Re: Bonded components in Nx
Sorry Wazy,
I have nothing generic to provide.
You rmodeling approach is part of the equation. You also need to determine what results you are after, and in what kind of solution. Then I suggest that you make small break out models using the different approaches, and see how these affect the desired results.
Phil
Philippe Tremblay
phillippe.tremblay.ext@siemens.com
www.mayahtt.com
