Convert FEMAP Visual Basic code to NXOpen Visual Basic code
We previously used the attached codes to extract the areas of the free element faces and the node numbers of a selected set of elements in FEMAP. Now, we are using NX Simcenter and we want to use the same code in NXOpen and we need to make the code compatible with NXOpen. We don't have experience with NXOpen scripting.
Can you please help us on this topic?
