Re: Customer Defaults for Post Processing
Thanks MiDi1791,
I will try to do someting different to apply small amount of templates.
I will show you my results when it succeeds!
Greets,
Jeroen
Mr MiDi1791,
We have 2 templates but it doesn't combine the result.
Only 1 tempate is shown in the post processing view.
How do i combine these two templates? see picture.
Shown in the picture is no edge style but we see a deformation of 10% we want to see this 0% and no edge style.
Can you help me with this problem?
Greets,
Jeroen
We have this code as tempate:
but this doesn't work this way...
i think we do someting wrong here.
JBrouw96,
I believe you did not activate the templates.
You should right-click onto template "No Deformation" and apply it and afterward you must right-click onto template "Edge_Style" and apply it, too.
Michael
| Production: NX10; Development: VB, TCL/TK, FORTRAN; Testing: NX11 | engelke engineering art GmbH, Germany
| Kudos for good posts! And if my post answers your question, please mark it as an "Accepted Solution".
Kick Off (2015-09-14)On the Map (2016-10-21)1st Gear 2018 (2018-02-19)To the Rescue (25, ‎2018-02-24)5th Birthday! (2018-02-25)Popular (100, ‎2018-10-30)Prolific (100, 2019-02-27)Philosopher (500, ‎2019-02-28)
Ok,
thank you for all your help so far.
We have activated the templates but that doesn't work, what should we do now?
Greets,
Jeroen
JBrouw96,
put each template into a separate file or
remove the inner lines
</PostView>
</NXPostprocessingTemplate>
<Postview>
and add
</PostView>
at the end.
<NXPostProcessingTemplate TemplateType="User" Version="NX8.5" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="PostTemplate.xsd">
	<PostView>
		<DeformationOptions>
			<ShowDeformation>0</ShowDeformation>
		</DeformationOptions>
		<EdgefaceDisplayOptions>
			<PrimaryOptions>
				<EdgeStyle>None</EdgeStyle>
			</PrimaryOptions>
		</EdgefaceDisplayOptions>
	</PostView>
</NXPostProcessingTemplate>
Save it as "NXPostTemplate_USER_001.xml" in your template directory and reload your templates.
Then you should see it and it shall make what it has to do. In my environment it works.
=> No Edges => No Deformations
 Best wishes, Michael
Thank you very much Michael we really appreciate your effort!
It works!!
Thank you very much for your help.
Jeroen
Jeroen,
All right, feel free to arrange all you setting for post views now ;-)
I think the larger problem ist to find good names and keep control.  Sometimes templates also vanish! - Therefore make backups!
Yeah true, that is a risk we have to take.
Thanks again!
Jeroen
