Re: Difference between element and Nodal element stress
HI Ionut,
I think that I uderstand your point now, however still assumption that crack appeard for stress less than yield, for me is just wrong unless it is not a fatigue case byt clear overloading of the strructure. But it's just my opinion.
What I can suggest try to use element CRAC3D, described Here.
I have never used it, but it seems to be answer for your problem with modeling of tiny notches.
As I can see it is suported by NX Nastran Basic Bundle.
Let me know if you will ger reasonable results Smiley Happy
Builder
Builder
Yes, it is a fatigue case. I will have a look at the element you mentioned, and I will keep you informed.
Many thanks
Ionut
Gears Valued Contributor Gears Valued Contributor
What was the solution?
