Export High Quality Images and Animation - Simcenter Thermal/Flow Solver Simulation Results
I have been working with Simcenter for a while and got some thermal/flow simulations results, however, the images or the animations which are exported have a very low quality. I was wondering if there are some settings I can change to get higher qualities for the exported images (and potentially HD). It is really surprising and annoying at the same that the export bottons do not have the option to change the export quality and there is a big chance there is an easy way to do it and I just dont know. I have search the forums and have came to some answers, however, I was wondering if there is an easier way to do it (here is an example what I could find in the forumes: https://community.plm.automation.siemens.com/t5/NX-Design-Forum/How-to-export-quality-Images-in-Simu...).
Thank you for your help,
Iman
Re: Export High Quality Images and Animation - Simcenter Thermal/Flow Solver Simulation Results
Using the File -> Export -> Image, you will always get a 1:1 image, like a screenshot, of what you're looking at.
Use Viz Mockup rather, with an exported JT file of your results.
Juan
