Flow Analysis application cannot be found
i am trying to do a flow simulation in the NX mold wizzard feature.
I have done a complete installation of NX12.02 on two different PCs.
I checked in all boxes of program features during the installation.
Had the problem also before on NX11.
Did anyone else encountered this problem?
Best regards,
David
Re: Flow Analysis application cannot be found
Hi David, You'll first need to install the Moldwizard add-on, you can find it on GTAC download center
Cheers,
Juan
