How does Bolt Pre-load work?
Gears Valued Contributor Gears Valued Contributor
Dear Experts,
how is the solution for a bolt pre-load approached/implemented in Nastran?
I read there are different approaches on different sites regarding bolt pre-load in general and used with other software:
"Pretension can generally be modeled with temperature, constraint equations, or initial strains."
Source: Methods for Modeling Bolts in the Bolted Joint
What is used for Nastran if I apply a bolt pre-load to an 1D-Element or a cut-plane?
Where can I read more about it?
Kind regards.
4 REPLIES 4
Re: How does Bolt Pre-load work?
The above link describes how to apply the preload in Simcenter.
For solver documentation see here:
Linear Solutions (101, 103, 105, 107-112):
https://docs.plm.automation.siemens.com/tdoc/nxnastran/12/help#uid:index_User:id505931:id677877
Multi-Step nonlinear (401):
https://docs.plm.automation.siemens.com/tdoc/nxnastran/12/help#uid:index_multi_step_nonlinear:xid119...
Thanks everyone!
@JimB
"Historically, bolt preload was modeled using either an equivalent thermal load approach or a multipoint constraint (MPC) approach." Bolt Preload
I know the first (thermal load approach), but not what is meant by a MPC approach.
Is anyone so kind to provide further details?
