Load SID 1 could not be found and must be present to continue!
I come across the problem when using Surface Dipole.And I don't know why it will happen. I use .cgns Data from Fluent and then run the "Moel and Load Pre-processing" with time signal processing and Mesh Mapping Data once.
捕获.PNG2.PNGThe setting in Surface Dipole
捕获.PNGThe error
The method of choosing Element Face Group is Feature Angle
