Material Orientation in Simcenter
Hi Pals,
Customer raised a question about elements material orientation definition in Simcenter.
Does anyone know in Simcenter how to setup correct material orientation definitioin of 3D elements, which definition is correspoding to fitting the standard axis to the surface parameters(S-T) direction in the legacy I-DEAS/ NX I-DEAS?
Thank you and best regards,
Wingston
