NXopen Java Multisession
I'm new in NX (11v) and NXopen. I'm trying to modifye a 3D NX Model template and a 2D Sketch.
I do erverything in Java and without starting NX itself. But i think the progrmmlanguage shoudnt be the problem.
I edit some Expressions and save the .prt some where else.
Now my Problem is, i want to run 3DModel editing and 2DSketch simultaneously.
One after One spereated is no problem. But so i have to quit the programm ervery time.
If i run it simultaneously i have Problem with my Session in one JVM (Java Virtual Machine) . I create the Sesseion und the UFSeffeion with the Session Factory.
UFSession ufSession = (UFSession) SessionFactory.get("UFSession");
Session theSession= (Session) SessionFactory.get("Session");
Is there anyway I can create a new Session?
Something like:
Session theSession2 = (Session) SessionFactory.get("Session2");
So i can separete the 3D Session an the 2D Session in one JVM?
Thnk you for your Support.
Production: NX11.0.2 TeamCenter 11.3.0.1
Development: Java Testing: NX11.0.2 Preparing: NX11.0.2 TeamCenter 11.3.0.1
Re: NXopen Java Multisession
ask your question in NX Programming & Customization Forum, you'll have a better chance of an answer
Production: NX.CAE 10.0.2.6
You are rigth!
Thank you for your Tipp. Havent seen this forum.
If some wants to follow here:
https://community.plm.automation.siemens.com/t5/NX-Programming-Customization-Forum/NXopen-Java-Multi...
