Reg: Creating Cyclic Symmetry.
Hello Everyone,
     I am a Master Thesis Student  and i am presently having problem in creating a cyclic symmetry between Surface 1 and Surface 2.
I want to create constraint equations betweeen surface 1 and surface 2. Kindly provide me with your insight on how i can over come this problem.
the link for the picture is under
https://drive.google.com/file/d/1dDDiRSzgPMQKfHIgr1PolwgGIOkuOhm-/view?usp=sharing
It would be of great help for me if you could help me in resolving this problem.
Hoping for a positive reply. Thanks in advance.
Best Regards,
Sanjay Gopi.
Re: Reg: Creating Cyclic Symmetry.
Sanjay,
The surfaces that you reference (the holes) aren't on the cyclic symmetry plane, therefore you shouldn't be coupling them. You do need to couple the planar faces, but I'm assuming those aren't your problem.
Mark
