Running a solution and laminate post prosessing report in batch
Hi
I am currently working a lot with laminates. My workflow is to first run the analysis to get a solution. Then, based on this, run a laminate graphical report to get laminate results. Because of the size of the problem this takes some time, and I need manually to start the second analysis after completion of the first.
Anyone knowing a way to run this as a "batch process". I am familiar with general Python programming, but is not familiar with NX open.
My version is Simcenter 12.
Geir Olav Guddal
