Solve subcase only?
Dear experts,
is there a way to solve only one subcase of a solution?
I've got two subcases right but messed up the other. After the correction of the messed up one, I do not want to solve the two correct ones again.
Cheers.
Re: Solve subcase only?
You can duplicate whole analysis case and remove all subcases except one you need.
But then I have 2 result files?
A way to combine?
Siemens Genius Siemens Genius
Siemens Genius
I think, easiest option is clone the existing solution having multiple subcase., Then in the newly created solution (by cloned) keep the subcase required and delete the unwanted one.
RB
Is this crucial?
