Sphere to Extrusion Analytical Contact
I'm trying to use a sphere to extrusion analytical contact but I'm running into some issues. Once I select a link under the extusion section, I am unable to select anything for "Specify Motion Extrusion". Apparently I need to select a sheet body. Is there a way to use the face of a link instead?
Re: Sphere to Extrusion Analytical Contact
Siemens Genius Siemens Genius
Siemens Genius
You need to select a sheet body that is defined by an Extrude feature in the Motion simulation model (in the sim file). In Motion application, Extrude feature button is in Tab 'Geometry'. Create the extrude as sheet body and then add that sheet body to your Link.
You cannot use any face.
Tips: To maintain associativity, when the geometry is in Master Part, use Promote Body or Wave link the body such as the selected edge remain associative. Then you have also other active geometry for  setting the extrusion length.
Documentaton reference is:
https://docs.plm.automation.siemens.com/tdoc/nx/12.0.2/nx_help/#goto:motion:xid1335358
Gilles Dubourg
Simcenter 3D
Siemens Digital Industry Software
gilles.dubourg@siemens.com
www.siemens.com/plm
After extruding, how do I add the sheet body to the link?
Siemens Genius
Simply edit the Link and select the sheet body. It will be added to the Link.
Link dialog focus is on Link Objects - Select Object.
Gilles Dubourg
Simcenter 3D
www.siemens.com/plm
Great thank you!
