general simcenter 3D motion solver model error
I am testing the motion but it appears an error like the image below:
I don't know how to fix it because I don't know where the error comes from?
I use NX 1867 in win 10 1903 and nvidia Quadro P4000 Graphic card. I look forward to everyone's help.
Thanks so much in advance
Thanh
Re: general simcenter 3D motion solver model error
Thanh
If you navigate to the location the .Sim file is saved to - there will be a .msg file that you can open with notepad. This will give you more details regarding the error.
I am unable to open the sim file you uploaded. Perhaps if you expand the motion navigator tree I can see what links/contacts etc you have setup.
Hi @Stuart_S,
After many attempts to fix it, I found the reason why I installed the missing library C ++ 2012. It does not work on C ++ 2015 and later.
Thanks for your support.
Thanh
