how to save the converged iterations of sol601 before stoping the solution in nx 10 & nx 11?
3 REPLIES 3
Re: how to save the converged iterations of sol601 before stoping the solution in nx 10 & nx 11?
can request outputs to be saved at every (converge) iteration. Default might be last one
Production: NX.CAE 10.0.2.6
Thanks.
Is there another way by creating a .rto file?
How to create .rto file?
The .rto file can only be used to stop the run or adjust parameter settings. It cannot be used to change output requests.
The .rto file must be manually created (i.e. via a text editor).
