Re: Contact analysis in SOL 601
Here is simple 1 hexa element model. Unpack it, copy dat file in new folder, then found in your NX dir/nastran/bin/nastran64L.exe or nastran64 or other nastran executable and run it. select dat file from archive and run it. Problem must be solved without FATAL errors in f06 file. If you get error - repair your instalation/computer setting.
No results found yet, may be a problem with the installation.
Hi  SamGeorge726,
by checking it I've got a license error in f06
 *** USER FATAL MESSAGE 1259 (GETLIN)
     PREPROCESSOR CONTROL VALIDATION FAILED.(A)
 *** USER INFORMATION:
     THE BULK DATA SECTION OF THE INPUT DATA HAS BEEN CHANGED OR
     WAS CREATED ON A DIFFERENT COMPUTER.
1                                        * * * END OF JOB * * *
So no results, because I've got only desktop license which means I can only solve NASTRAN decks which
were created at my own PC.
May be, it's your problem, too?
Best wishes, Michael
| Production: NX10; Development: VB, TCL/TK, FORTRAN; Testing: NX11 | engelke engineering art GmbH, Germany
| Kudos for good posts! And if my post answers your question, please mark it as an "Accepted Solution".
Kick Off (2015-09-14)On the Map (2016-10-21)1st Gear 2018 (2018-02-19)To the Rescue (25, ‎2018-02-24)5th Birthday! (2018-02-25)Popular (100, ‎2018-10-30)Prolific (100, 2019-02-27)Philosopher (500, ‎2019-02-28)
Is there any constraints with having Nx Academic Perpetual License?.
