Edge-To-Surface Glue contact: 2D coat required on solid face?
doing a check on a Glue Edge-to-Surface.
Does one need to put 2D elements on the face to which the edge is to be glued to?
Production: NX.CAE 10.0.2.6
3 REPLIES 3
Re: Edge-To-Surface Glue contact: 2D coat required on solid face?
Gears Legend Gears Legend
Gears Legend
No. The surface region can either be 2D or 3D element faces.
Thanks. So the bending from the shell element edge is transmitted to the solid ?
Gears Legend
Yes.
