Export every nodal displacement across a frequency range
Hello! I have solved a model with sol 108, so that I have the displacements across a frequency range for every node.
Now I would like to export for each node these displacements across the frequency values.
When I try to create a graph containing the displacements for every node in order to export the results on an excel I am limited to 50 nodes per graph, which is quite small.
Is there any other solution?
Re: Export every nodal displacement across a frequency range
If you solve the model and request SORT2 output format, Nastran will save results in exactly this format. Use the PUNCH output option to get this data into the ASCII punch file.
