Mesh points ignored
Gears Valued Contributor Gears Valued Contributor
Hello!
I am working on a .fem-file consisting of several bodies.
I created mesh points at the center of some bolt-heads.
Mesh points applied by "arc center" method are ignored after meshing the surface. Why?
But mesh points applied by "inferred" method are considered after meshing the surface.
Also, mesh points applied by "arc center" method in another .fem-file consisting of only one body (the bolt-head) are also considered.
What is going on?
Do I have to somehow assign/attach/associate mesh points created by "arc-center"-method to the desired face when having multiple bodies? If yes, how?
Re: Mesh points ignored
Did no one else experience this yet? Maybe this is just a a bug.
