SET_SEGMENT/NODE in NX for LS-DYNA solver
Dear all,
I am using NX NASTRAN 12 as pre-post for an explicit simulation in LS-DYNA.
When I create the *.fem file, I impose LS-DYNA as solver, so that when I will export the mesh, I already get a *.k file containing the keywords for parts, elements and nodes.
So, my question is if I can already define *SET_SEGMENT or *SET_NODE in NX NASTRAN. I can not find the icon (in the NX screen) where to define these regions.
Now, I am exporting the mesh and I define these commands in the LS-S-DYNA prepost, but I would like to optimize the operations by doing everything in NX.
Does anyone know how you can help me?
Thank you very much.
Kind regards,
Ivan
Re: SET_SEGMENT/NODE in NX for LS-DYNA solver
Nobody?
I'm not familiar with the LS-DYNA environment, but the following article in the documentation details export support by card:
LS-DYNA keywords supported for import and export
It looks like *SET_SEGMENT is not supported and only *SET_NODE_LIST_(TITLE) is currently supported for export
