SOL 601
I am not being able to view the results, even though the op2 file has generated.
Kindly suggest a way to rectify the problem.
Re: SOL 601
.op2 file is generated even if analysis has crashed. Check your analysis has actually succesfully completed
Production: NX.CAE 10.0.2.6
Re: SOL 601
I have checked for errors/fatal in the f06 file, and it doesn't show up
any, except for some warning.
Re: SOL 601
SOL 601,129
Solution > Case Control > Output Requests > Sorting > For each request, change sorting type "default" to SORT1
Re: SOL 601
Thanks. I have updated the SORT1 option to all output request. Some warnings exist still.
Re: SOL 601
Are you still unable to see the results? or those warning a different issue?
Try clearing the T(*) values from MATT1 as the warning suggest and see if this helps in any ways.
Feel free to share the *.dat file if you want someone to look into this for you.
Re: SOL 601
- Do you check if it is statically determinated? Check if there are rigid modes using a SOL103.
- A static linear solution give resonable results?
- What happen if you apply only 10% of the load on your non-linear simulation? Does the simulation run properly and give you correct results?
