Shock Response analysis problems
I have serious problems completing a SRS analysis in both FEMAP and NX/NASTRAN. In FEMAP, the program will not write the Shock input (TABLED1). So I had to input the TABLED1 manually. When the TABLED1 is entered and I run, I get
*** USER FATAL MESSAGE 1250 (BIOWRT)
(I have also had other USER FATAL MESSAGE) but they are mostly 'cryptic'
Anyone with SRS experience?
Re: Shock Response analysis problems
We have tons of experience with SRS, but this seems more like a memory issue... Any way you can share more of the f06 errors?  Does this solve if you perform a simple SOL103, i.e. removing the DLOAD, SUPORT and PARAMs specific to SRS?
