Solver input file not found
Innovator
Innovator
When I click on "Solve" there is no error  of meshing or boundary conditions but in the solution monitor,this error occurs.
Can you help me please?
Sonny
Re: Solver input file not found
the nastran input file does not exist in the specifiedf folder is my guess !
Have you actually check what you have in specifiedf folder ?
Production: NX.CAE 10.0.2.6
Innovator
Innovator
@selex_ct,Thank you for your reply,Yes of course.
Siemens Creator
In the ribbon bar under "Home", hit the SOLVE button  and select "Write solver input file". In the text window that appears, scroll up to find the directory the file was written to. It should say something like "Writing file <path_to_file>". Confirm that the <path_to_file> is the same as .\Solution_1 or whatever you want it to point it.
