Re: WHAT IS THE ISSUE IN THIS MODEL PLEASE
Since you use CQUAD 8 ( CQUAD 4 will do the job to), you should use plain strain to avoid instability . Since you problem is a plan strain one. Edit the properties of the 3 collector you used and select the "plain strain" option.
Builder
Builder
Naquib,
Golden suggestions from you. Thanks a lot for your support
