result_output forum
Why is "Result file in wrong format" popping for structural anlaysis results?Is it regarding any license issue.
Re: result_output forum
If the model was generated in Simcenter and the solution was launched from Simcenter, then the most likely reason is that the solution sis not complete successfully and so there are no results in the .op2 file.
Check the .f06 file for FATAL errors.
