CGNS interchange possibility--How to export CCM+ mesh data to Simcenter 3D?
 Hi Pals,
Customer asked if we could export CCM mesh data into Simcenter 3D for further process.
I found that CGNS format could be the possible way.
But in Simcenter 3D, importing CGNS file function only shows in the flow/thermal module.
I tried, but failed, with no detail to check error.
My CGNS file seems OK, because I could create a new sim, import CAD jt part, then import my CGNS mesh back to CCM.
So I am looking for any help for this issue.
Thanks and best regards,
Wingston~~
ScreenHunter_3310 Sep. 07 17.39.jpgScreenHunter_3311 Sep. 07 17.40.jpgScreenHunter_3313 Sep. 07 17.41.jpgScreenHunter_3314 Sep. 07 17.56.jpg
Re: CGNS interchange possibility--How to export CCM+ mesh data to Simcenter 3D?
I am not sure what the error means in Simcenter 3D, so I would recommend getting in touch with your local support for Simcenter 3D.
But I would ask, what processing is needed in Simcenter 3D instead of STAR-CCM+?
STAR-CCM+ has rather comprehensive post processing capabilities. Maybe we can help you more there.
