Star CCM+ Co Simulation Problems
I just suffered a problem when running Star CCM+ coupling simulation with GT-Power, can someone help to sovle the problem?
The problem occurs when pre-running in GT is finished and then Star and GT start to communicate, it shows as the following:
ArrayStorage():getSimpleStorageComponent(): index out of range
Command: Automation.Run
   Recoverability: Non-recoverable
Re: Star CCM+ Co Simulation Problems
Hi there,
Thanks for posting and please accept my apologies for the delay in responding to your message.
Unfortunately, this forum is not able to help with detailed technical issues, however I would ask you to open a support case with your DSE (dedicated support engineer) via the Customer Portal. They will be able to help you to troubleshoot your co-simulation.
Kind Regards,
Alex
