Block UI Styler error
Hallo !!
i am working with (Block UI Styler )and i get this error :
Error Number: 943006
the picture is taken from the log file!
Re: Block UI Styler error
Moderators please move to customization and programming forum.
@Kutayba, have you already tried searching for the error number in the Solution Center ?
i dint find any thing about this error in Solution Center ,
and i change it to the customization and programming forum.
From "%UGII_BASE_DIR%\UGOPEN\error_bases.h" this seems to be an error within the UG manager base.
Are you running your dialog within a managed NX session (with Teamcenter)?
#define ERROR_UGMGR_base    940000
%UGII_BASE_DIR%\UGOPEN\uf_ugmgr_types.h
#define    UF_UGMGR_error_base                 ERROR_UGMGR_base + 3000
#define    UF_UGMGR_invalid_fname              (UF_UGMGR_error_base + 6)
So it seems that you are trying to use an invalid file name for the action you are taking.
This was found by using the "find in files" feature of Notepad++ Smiley Wink
